Tiling
  • May 21, 2018 7:17 PM UTC
  • 73 views
dszarka
I have three very large Microstation file that I would like to clip into smaller individual tile files. I have looked at clipper, but it appears that I can only write out a single file. I would use tiler but the tiles that i would like to write out are different sizes and shapes.Not sure the transformers I need to use to get the results I am looking for.
danilo_fme
Forum|alt.badge.img+58
  • May 21, 2018 7:43 PM UTC
Hi @dszarka,
Please, see this link if is similar in your case: https://knowledge.safe.com/questions/3849/limit-csv-writer-size.html
Thanks,
Danilo
  • May 21, 2018 10:33 PM UTC
Hi @dszarka, do you have some polygon features corresponding to desired areas for each destination file? If so, you can clip the features from the source Microstation datasets by the polygons then write the clipped features into destination files separately using the Fanout functionality.
