tester loop through values
  • April 4, 2014
  • 61 views
I have a script that currently uses a user supplied ID value to search through four different geodatabases for features with the requested ID and updates data in an Excel file with the found features.  It's quite simple: each geodatabase with its own Tester, the Right Value set to the appropriate parameter, all writing to a separate tab in an Excel writer which uses a template file.
What I'd like to do is modify so instead of the user entering a single ID to search for, it can loop through  multiple IDs in a table to look for and create an excel file for each ID.  How I imagine it would work is to pass the values from a table one at a time to the Tester transformers.  However, I'm still quite new to FME and I have no idea if this is possible.
Does anyone have any thoughts on how this might be accomplished?
fmelizard
Forum|alt.badge.img+22
  • April 5, 2014
I would change the testers with a SQL executor with a where IN clause.
You can create the IN value by aggregating the id's. Once the features are returned use a fanoit .
fmelizard
  • April 6, 2014
typo : fanout....
optionally a FeatureReader per gdb with a where IN clause is also a possibility.
