Tester $(FME_ENGINE) Attribute Has a Value fails on FME Server 2019.1.2
  • Nov 20, 2019 3:05 PM UTC
  • 144 views
nielsgerrits
Forum|alt.badge.img+67
I have some strange behaviour with a Tester on a FME Server Parameter.
In a workspace designed to run on server I test if $(FME_ENGINE) has a value. When this passes it initiates a subsection which I don't want to run when I develop the workspace locally.
This worked fine in server 2016 but it fails in server 2019. Could reproduce this in a fresh 2019 workbench.
FME server log returns:
Tester (TestFactory): Tested 1 input feature(s) -- 0 feature(s) passed and 1 feature(s) failed
Is this ment to work this way?
erik_jan
Forum|alt.badge.img+26
  • Nov 20, 2019 3:41 PM UTC
This is probably caused by the fact that $(FME_ENGINE) is not an attribute, but the value of a published parameter.
Use the AttributeCreator to create an attribute (FME_ENGINE) with the value of the parameter.
Then use the Tester on the attribute instead of the parameter.
Hope this helps.
jkr_wrk
Forum|alt.badge.img+37
  • Aug 23, 2021 8:13 AM UTC
To clearify. FME is actualy doing this:
@Value($(FME_ENGINE)) HasValue
So if $(FME_ENGINE) = FME01_Engine1 it checks if there is an attribute with the name FME01_Engine1 and if that has a value.
To me it seems like the @Evaluate(). It is a somewhat hidden step FME takes.
You could for instance do @Evaluate(1+1)-@Evaluate(1+1), which results in the string 2-2. In the AttributeCreator it shows up as 1+1)-Evaluate(1+1.
So if you test if $(Prefix) = pre_ then it is true but if $(Prefix) HasValue it is false.
