Test if an input time is between two times?
  • Dec 17, 2021 9:14 AM UTC
  • 136 views
Hello, I am attempting to test if an input date exists between a date range - I'm struggling to find the correct syntax or transformers to do this (after 40 minutes of trying). Can anyone help?
Currently my input is to AttributeCreator the time for now - @DateTimeFormat(@DateTimeNow(),%T)
Then so far I have used a Tester to see if it was greater or less than two times e,g, >= @DateTimeFormat(09:00:00, %T) OR <= @DateTimeFormat(09:05:00, %T)
But predictably this doesn't work as it will always be greater or less than one or the other. I would like to use BETWEEN (if I was using SQL).
Is there an efficient way to do this in FME? Other than converting the time to a number (which would mean regex-ing the leading '0' up to midday) and then comparing numerical values in a (presumably) AttributeRangeFilter?
Apologies if I am missing something basic! Help very much appreciated 🙇‍♂️ 🇬🇧
Best answer by redgeographics
If you use an AND instead of an OR in your Tester expression it should work.
Forum|alt.badge.img+63
  • Dec 17, 2021 9:38 AM UTC
Thank you - I think I tried AND before and it didn't work, but I didn't set the Left Value a second time - which is why it failed.
I thought it would be a simple answer! Thanks for your help!
