TemplateToDocumentBuilder: Platzhalter im Word-Template: Zahl als Währung formatieren
  • Jan 28, 2026 8:01 AM UTC
  • 150 views
paula
Forum|alt.badge.img+3
Hello,
I use the TemplateToDocumentBuilder. All numbers are formatted equally. I would like to format as current. 4233,78 --> 4.233,78 €
How can I do this?
Best answer by hkingsbury
The currency symbol and 1000s separator are not part of a double. They’re string presentation elements added to the double to provide context and readability for the user. Once they’re added, the value is no longer numeric and is therefore a string.
If you need to keep it as a double (for calculations or sorting), your best bet would be to make a new attribute that has the value as your required string presentation and keep the original as a double.
hkingsbury
Forum|alt.badge.img+73
  • Jan 28, 2026 6:58 PM UTC
There’s a bit of a discussion here about doing that
paula
  • Jan 29, 2026 6:26 AM UTC
Hello hkingsbury, thank you.
It seems to me like a string-editing? I would like to keep it as a double precision.
hkingsbury
  • Jan 29, 2026 6:42 PM UTC
paula
  • Jan 30, 2026 6:28 AM UTC
Thank you for clearing up the thoughts!
