Template file in Excel Writer
  • Mar 25, 2022 11:01 AM UTC
  • 132 views
Error_writing_Excel_Fileimage
Hi !
I'm having a problem while writing into a template file, see image of log error. In fact, out of about 20 translations, there is one with this problem arising while writing data. Can someone tell me if it's a bug with FME or about my parameters ? I doubt the problem with my parameters, because very often it works well while wring the Excel file.
Please help !
Thank you.
@sam.27​ FME is crashing. You should probably file a case with support and include the workspace, sample data and full FME log file.
  • Mar 28, 2022 7:59 AM UTC
Hello markatsafe
You are right, it happens only when I have huge amount of data to write !
Thank you !
