Tags to segment of polygon
  • March 20, 2015
  • 62 views
Hello there,
I discover the situation, that in my CAD (dgn, Microstation) data exist tags (label) to the part (line) of a polygon (igds_type: shape). I'm able to get to tags which are connected to the whole polygon, not when it's connected only to a part (line). Any solution how to get to tags through FME?
Hope the picture will help to understand. Blue color is the polygon and light blue is the line with a tag with the number 15 which is called oc. I can normally see tags called tp and sc but not oc and ul.
Thank guys for your help.
pratap
Forum|alt.badge.img+12
  • March 30, 2015
Can you provide a sample data ?
Pratap
  • April 8, 2015
Halo Pratap,
you can download dwn sample data here: https://drive.google.com/file/d/0B40z1ZRVQ87QUVdGUE5qejhGREU/view?usp=sharing
Sorry for late respond.
Thanks for your help.
Anna
