Tabular data: merge / transpose data based on keyword
  • Dec 20, 2018 7:24 AM UTC
  • 12 replies
  • 151 views
I'm trying to combine two data streams based on keywords. (chain)
How can I do this?
Thanks,
Ed
Best answer by david_r
Here's a possible solution using a FeatureMerger to create a category list for each CHAIN element, then a BulkAttributeRenamer to "explode" the list items. You will have to manually expose CAT0...CATn, however, e.g. using an AttributeExposer after the BulkAttributeRenamer. Also note that the CAT attributes start at CAT0, not CAT1.
merge_categories.fmwt
  • Dec 20, 2018 8:29 AM UTC
  • Dec 20, 2018 8:36 AM UTC
If you really need the CAT attributes to start at 1, you can replace the BulkAttributeRenamer with the following small code in a PythonCaller:
def ExplodeList(feature):
    items = feature.getAttribute('_categories{}.Category')
    for n, item in enumerate(items):
        feature.setAttribute('CAT%s' % (n+1), item)
  • Dec 20, 2018 8:48 AM UTC
Hi David, thanks for your response.
I'm not getting the output I'm looking for:
Attached what I have now (beta 2019) - If you have time, could you please have a look?
merge_categories2.fmwt
Thanks,
Ed
  • Dec 20, 2018 8:52 AM UTC
Thanks,
Ed
Could you please re-upload the template with the accompanying Excel files? That'll make it a lot easier to test.
  • Dec 20, 2018 9:47 AM UTC
merge_categories2.fmwtInput_categories.xlsxInput_chains.xlsxMmm, I thought a template FME file contains all related files. Anyways, I've attached all files. Thanks
  • Dec 20, 2018 10:02 AM UTC
I was able to get desired result from your workspace, with FME 2018.1.1.1.
There could be issues in the Beta. Why not use a release version?
  • Dec 20, 2018 10:12 AM UTC
@david_r / @takashi
Thanks gentlemen, you're right, it works in 2018.
I started using the 2019 beta when I encountered some crashed with the 2018 version :-( Guess I have to switch back!
Cheers,
Ed
  • Dec 20, 2018 10:13 AM UTC
Seems to be an issue with the BulkAttributeRenamer in the 2019 Beta. You should consider signalling it to Safe.
But I agree with Takashi, why use a beta version at all. Unless you have a very specific reason I would actually recommend against it.
If you really need to use the 2019 Beta, consider replacing the BulkAttributeRenamer with the PythonCaller and the code I posted above, it should work.
  • Dec 20, 2018 10:32 AM UTC
Thanks,
Ed
Good to hear you got desired result.
This is another approach. I don't think merging two tables is essential in this case. FYI.
  • Dec 20, 2018 10:37 AM UTC
Apologies David, my Python FME knowledge is non existent.
Where do I paste this piece of code in the PythonCaller? (I mean what parts of code in the PythonCaller should I keep?)
What should all the settings look like?
Thank you
  • Dec 20, 2018 10:42 AM UTC
Thank you
It should look like this:
There should be none of the template code, only the code you copy/paste from the posting above.
farfar
Forum|alt.badge.img+12
  • Dec 20, 2018 11:00 AM UTC
I tested a David solution with 2017.1 version and it works also.
