Table/Feature class name too long
  • September 30, 2021
  • 9 replies
  • 93 views
itay
Forum|alt.badge.img+17
I am trying to IMPORT an EXISTING relationship feature class and FME complains about the name being too long....I cannot rename the Relationship feature class since it is a part of an existing data model.
The table/feature class name 'WaterstaatswerkWaterkering_Waterkering' is too long for Oracle (!!??) to accept. Please shorten the name and try again
I think this is a FME limitation that should apply if you are going to CREATE the table, but should not apply if the table/relationship feature class already exists!
Anybody any thoughts/ ideas on how to go about this?
Best answer by itay
itay wrote:
Hi @Hans van der Maarel​ , That is exactly my point, but this does not make any sense if you are trying to insert data into an existing relationship feature class and not create it.
Hi @steveatsafe​ ,
Thanks for taking the time to look into this issue, is it possible to continue this as a support case? ( I dont think sharing client information and data should take place on the community pages)
Forum|alt.badge.img+50
There does appear to be a max table name length of 30 characters in Oracle, or 40 characters for a logical table name stored within an entry table, so it might be that that limitation is maintained somewhere within FME.
itay
  • October 6, 2021
Oh, I agree. It appears there is a limitation in there somewhere that shouldn't be there.
itay
  • October 25, 2021
Yes that is the case. I have had a look at this issue with the DBA and since Oracle 19c is used this should not be an issue, since this version of Oracle allows for 128 charachters, somehow FME does not respect that or defaults to previous versions.
I defntly think somebody from Safe should chime in...@mark2atsafe​ , @steveatsafe​ ?
steveatsafe
Forum|alt.badge.img+12
  • October 25, 2021
Hi @itay​ Thanks for bringing this to our attention. I'll look into the issue and update you here.
steveatsafe
  • October 25, 2021
Hi @itay​ Can you confirm the version of FME you are using? You may need to upgrade to a newer version. Also, consider the Oracle Client version you are using as well. I'm on 19.3 Instant Client on macOS.
I've tested this in. 2021.0 - 2021.2 (beta) and had no issues. I was able to write to a table called
"WATERSTAATSWERKWATERKERING_WATERKERING" or "WaterstaatswerkWaterkering_Waterkering".
[edit] I've also tested with 2020.2 & ArcGIS Desktop 10.7 with Geodatabase on Oracle and had no issue as well (use existing|truncate|create if needed). I was using Oracle Instant Client v19.6 on Windows OS for this test.
There's a good chance this was addressed when we added the new Oracle Autonomous format.
itay
  • October 26, 2021
Hi @steveatsafe​ ,
steveatsafe
  • October 27, 2021
Hi @itay​ Please submit a case via www.safe.com/support (Submit a Case). Feel free to address me in the case or include the link to this question.
Thanks.
itay
  • October 27, 2021
@steveatsafe​  done! > C663864
