SystemCaller with xcopy /I /E /Y /T doesn´t create a directory
  • Mar 7, 2024 1:39 PM UTC
  • 6 replies
  • 224 views
gjaguilar
xcopy "$(TEMP_FOLDER)\$(FME_JOB_ID)\Temp"  "$(TEMP_FOLDER)\$(FME_JOB_ID)\Results" /I /E /Y /T
From the command line I use xcopy /I /E /Y /T and if the directory does not exist it creates it but within a SystemCaller it does not work and does not give an error message.
I need Help
becchr
Forum|alt.badge.img+35
  • Mar 7, 2024 3:15 PM UTC
hi @gjaguilar does it make any difference if you put the entire command itself between extra quotation marks like this?
“xcopy "$(TEMP_FOLDER)\$(FME_JOB_ID)\Temp"  "$(TEMP_FOLDER)\$(FME_JOB_ID)\Results" /I /E /Y /T”
gjaguilar
  • Mar 7, 2024 3:21 PM UTC
Thanks, I´ll try
gjaguilar
  • Mar 7, 2024 5:20 PM UTC
It does not work
I enclosed in double quotes and it doesn't work
the process stops to ask if it is a file or a directory
Locally using /I /E /Y does it fine
geomancer
Forum|alt.badge.img+71
  • Mar 8, 2024 8:41 AM UTC
Ah yes, quotes inside quotes. This works (with and without spaces in the folder names):
"xcopy """@Value(FilePath)""" """@Value(TargetFolder)\Results""" /I /E /Y /T"
gjaguilar
  • Mar 8, 2024 8:46 AM UTC
Thanks, I´ll try  again
gjaguilar
  • Mar 13, 2024 9:22 AM UTC
 I added a FileExistenceChecker transformer to check if the directory exists before using xcopy; otherwise I use another SystemCaller to create a directory with mkdir.
Thanks a lot
