systemcaller hide cmd
  • Mar 12, 2019 2:30 PM UTC
  • 87 views
oliver.morris
Forum|alt.badge.img+14
Hi, is it possible to hide the systemcaller cmd line when using it inside a workspace being run from workspace runner. At the moment my screen looks like this and it is a touch annoying!
Thank you
erik_jan
Forum|alt.badge.img+26
  • Mar 12, 2019 2:32 PM UTC
Depending on the command you are using.
Many DOS commands have a quiet mode, that will allow you to hide the window.
I would look at the help of the command you are using to see if such a quiet mode exists.
oliver.morris
  • Mar 12, 2019 2:38 PM UTC
thanks, while there is a quiet mode for tesseract when adding this, the cmd window still pops up but is empty.
