System caller : comand line works in cmd not in system caller
  • Jun 26, 2020 2:40 PM UTC
  • 176 views
Hello,
I am using 7z to unzip files and would like to use it through System Caller. The command works perfectly fine in cmd, but not in system caller.
Here is my command :
"C:\\_temp\\7z.exe" x "C:\\_temp\\input\\data.zip" -o"C:\\_temp\\output"
When this line is written in a .bat file and this file is executed through System caller, it works.
What should I do to be able to execute my command directly in system caller?
Many thanks in advance,
becchr
Forum|alt.badge.img+35
  • Jun 26, 2020 3:29 PM UTC
hi, @cadfmegeo, is it working if you put the command itself between extra marks like this?
""C:\_temp\7z.exe" x "C:\_temp\input\data.zip" -o"C:\_temp\output""
  • Jun 29, 2020 1:25 PM UTC
Thank you very much, it works very well that way!
