Symbolise Layers in HTML Report Generator / HTML Layouter
  • Apr 13, 2022 3:11 AM UTC
  • 270 views
deanhowell
Forum|alt.badge.img+24
I have a map that has 5 layers in it and want to have them all displayed using different symbology in the HTML Layouter but I can only define a single colour for the layer.
Is it possible to generate HTML output with a little more cartographic input for each incoming layer?
ctredinnick
Forum|alt.badge.img+22
  • Apr 13, 2022 5:11 AM UTC
You'll probably have to do it yourself in the code. Thankfully it's not too complicated. Some style information is here: https://developers.arcgis.com/esri-leaflet/styles-and-visualization/style-a-feature-layer/
But you can use a StringReplacer to replace the line controlling how FME styles it
style:{"color": "rgb(200,0,255)"}
with something like this, basically copying from esri's example
style: (feature) => {
let style = {
  color: null // no outline color
if (feature.properties.name === "73980") {style.color = "rgb(200,0,255)";}
else {style.color = "rgb(0,0,0)";}
return style;
Just using If statements to colour features differently. The feature.properties.name refers to the "name" attribute on the features, whatever that happens to be for your case.
deanhowell
  • Apr 14, 2022 2:25 AM UTC
Thanks @ctredinnick​ that is certainly a great option.
j.botterill
Forum|alt.badge.img+69
  • Nov 29, 2023 5:49 AM UTC
For those following this question, please vote up these ideas
AC Idea: HTMLReportGenerator Table Styling (safe.com)
AC Idea: htmlreportgenerator - allow for layer colour to be linked to attributes (safe.com)
AC Idea: HTMLReportGenerator improvement suggestions (safe.com)
Ideally the htmlreportgenerator content settings would allow the "Color Layer" to make use of conditional values so you can style different fme_feature_types for exampletransformers_with_color_conditional
