Swap/Rotate profile onto XY-space
  • Oct 16, 2024 3:58 PM UTC
  • 69 views
mariaka
Forum|alt.badge.img+15
Hi there,
I have severale profiles, which fly somewhere in 3D space.
The elevation always follows the z axis. The direction varies, but follows one direction in XY level.
I started like this:
  1. BoundsExtractor
    get the bounds (aka rotation axis)
  2. GeometryRefiner
    do some geometry refining
  3. 3DRotator
    rotate around the axis
Result:
3D view
2D view
red: rotation axis
grey/black: original geometry
green: rotated geometry
I expected the green geometries to be rotated around the axis, but instead they are rotated into 3d space 😵‍💫 I also tried to set the axis through the geometry (z = zmax-zmin), but with no success.
Can somebody help?
Cheers,
Maria
Best answer by mariaka
I found a way to solve this issue:
  1. get azimuth angle (HorizontalAngleCalculator)
  2. rotate everything to north (around z axis) (Rotator)
  3. swap coordinates (CoordinateSwapper)
  4. remove z values (2DForcer)
mariaka
  • Oct 17, 2024 3:36 PM UTC
