Surface Modeller "minimum number of points"
  • February 25, 2019
  • 83 views
I want to create a DEM from Multipatch-geometry contained in a geodatabase, for doing that I thought using the surface modeller could work, where in surface modeller I group the points by the UUID generated attribute:
But the errors are
"The specified cell size of '2' units in the y axis is invalid. Cell size must be less than raster extents"
"Surface Model cannot be constructed. Either all points are linear or initial set of points did not consist of 3 non NAN elevations"
For the first error I think it's due to objects with 3 points in less than a diameter of 2 meters
Second error is due to objects with less than 3 points
Questions:
1) how could I exclude/drop/ignore geometries with less than 3 points ?
2)how could I still add a cell value to objects less than 2 m ?
gio
Forum|alt.badge.img+15
  • February 25, 2019
@raphaelvallat11
If you group the points by a unique identifier then you are actually trying to build surfaces with a single point. (each is a group of 1)
(Unless they were aggregates prior to assigning a UI.)
Of course this causes the second error message, as unit 2 is larger then 0.
You need to check why you are Grouping in the Surface Modeller. As far as I can see there is no reason for it in your example, as you seem to be grouping objects to single object groups.
gio wrote:
@raphaelvallat11
@gio Thank you. The geometry of the input is multipatch, I m not familiar with it and may not be understanding it correctly. I think but I'm not sure that every multipatch feature has a unique ID (in my case every building), and all points (vertices) of each feature are grouped by one ID in the UUID generator. I tried without the UUID generator, and the problem is that it does interpolate a DEM in between buldings, where I actually want NoData. And one raster per building, which I would later merge in a mosaicker. Any thoughts on my reasoning ? or it could work
