Summarize data\\Transpose
  • May 6, 2021 1:56 AM UTC
  • 58 views
mark_zl
Hi I'm not sure on the correct transformers to do the following?
transpose
source data
sourcedata
daraghatsafe
Hi @mark_zl​ welcome to the FME Community. This article may help you out with you question https://community.safe.com/s/article/transpose-a-table-using-fme. Hope this helps.
mark_zl
  • May 11, 2021 8:49 PM UTC
Thanks I tried the Attribute Transposer (see image below)
attribute transfomerExample 2 and 3 worked but now what I was after. (Image below)Half transposeI'm after Transposing the Parking Type but keeping the ID's in a column
The current model
current model
