Sumifs/Averageifs in FME
  • Aug 3, 2018 2:43 PM UTC
  • 96 views
Is there a way of being able to replicate excel's sumifs/Averageifs functions in FME?
I have two tables, the first table has unique ID's and the second table contains data which I need to aggregate. Is there a transformer where I can use the unique values in table 1 to match against the data in table 2 to perform a Sumifs?
Thanks in advance.
owen
  • Aug 3, 2018 2:54 PM UTC
Hello, yes you can use the 'group by' function on the statistics calculator. Might need to join your tables, although not clear on that from your post. Owen
  • Aug 14, 2018 7:46 AM UTC
Thanks for your help!
