Suggested Command-line to run a workspace doesn not work
  • November 16, 2018
  • 6 replies
  • 51 views
I have a workspace that has a published parameter of type Filename (Multiple)
and I have multiple files in a folder with spaces.
At the top of my fmw file is says that this should be the command-line to run the workspace
"C:\\Program Files\\FME\\fme.exe" "ImporteerTrimble.fmw"
--DB_Service "ODSDEV"
--DB_User "GVR"
--DB_Password "********"
--Project_ID "22"--SchemaName "INWINNING"
--Bronbestand """D:\\Path with space\\file1.dxf" "D:\\Path with space\\file2.dxf"""
But when I run this command line it complains that there are uneven number of command line arguments.
I just can't get this to work from the command line, running within FME Workbench does work.
When I remove some quotes it accepts the arguments but then the reader fails
AutoCAD Reader: Unrecognized extension for source file 'D:\\Path'.
Best answer by takashi
The command line shown on the log could be wrong. It's a known issue. Try changing the file paths parameter to this one.
--Bronbestand """""D:\Path with space\file1.dxf"" ""D:\Path with space\file2.dxf"""""
erik_jan
Forum|alt.badge.img+18
  • November 16, 2018
The issue is that the command line needs to be 1 line.
You can use the ^ sign to continue the line like this:
"C:\\Program Files\\FME\\fme.exe" "ImporteerTrimble.fmw" ^
--DB_Service "ODSDEV" ^
--DB_User "GVR" ^
--DB_Password "********" ^
--Project_ID "22"--SchemaName "INWINNING" ^
Hope this helps.
  • November 16, 2018
Hi Erik jan, I just posted it as its shown in the workspace but I have it all on one line and tried way to many combinations and even with a parameter file, I just can't get it to work. Either there are uneven parameters or the reader sees only the first part of the path.
erik_jan
  • November 16, 2018
--DB_User "GVR" ^
Hope this helps.
Hi Valentijn,
I can see potential issues:
The "22" and --SchemaName seem to be connected (not separated by a space).
The quotes around the value for Bronbestand (not sure about the number of quotes).
I suggest trying the --SchemaName on the next line and changing the quotation for Bronbestand.
  • November 18, 2018
  • November 18, 2018
So the format is three quotes around the whole and two quotes around each filename and separating the files with a space. That works thanks takashi.
I think I kept balancing the number of quotes around the whole with the ones around the filenames but the whole is an uneven number of quotes and the filename are even quotes.
  • November 18, 2018
In my understanding, the rules are:
  1. Quote each path by a pair of double quotations and concatenate them separating by spaces. "<path1>" "<path2>"
  2. Then, surround the entire string by a pair of double quotations. ""<path1>" "<path2>""
  3. Further, in a command line, a parameter value should be quoted by a pair of double quotations, if the value contains a space. """<path1>" "<path2>"""
  4. Finally, every double quotation except the outer-most ones should be escaped by inserting a double quotation mark in front of each of them. """""<path1>"" ""<path2>"""""
I hope the translation log displays a correct command line always.
