Struggling to extract all the flattened JSON features using the JSONFragmenter
  • February 9, 2022
  • 42 views
dangeerah
Hi all,
I am trying to extract the following attributes from my JSON file: "area": "perimeter""laFeatureType" (plus some others) from the attached JSON file.
I am using a JSONFragmenter with the query json["data"][*]  but it isn't extracting as expect (all returns with "missing" data although I can see the data within the JSON file) .
Screen shot of my fragmenter attached.
Any help much appreciated.
Thanks
nielsgerrits
Forum|alt.badge.img+56
The reason this does not work is the _response_body is not valid json. I think it is RTF, (Rich Text Format). Not sure how to process this in FME. I found an 8 year old answer where a Python solution was proposed to convert to plain text.
If I manually remove all jibber jabber in rows 1 to 7, the first part of row 8, and all backslashes I get valid json:
	"type": "Feature",
	"geometry": {
		"type": "MultiPolygon",
		"coordinates": [
					[214452.8969869.19],
					[214453.169875.93],
					[214422.7669899.66],
					[214420.0469901.23],
					[214406.3569909.14],
					[214378.8569921.14],
					[214323.3969940.64],
					[214290.0169864.87],
					[214283.3869853.43],
					[214277.2369843.87],
					[214275.1569840.56],
					[214265.6869820.38],
					[214260.8269804.28],
					[214255.6569772.41],
					[214253.3869760.59],
					[214254.0269757.16],
					[214254.3869755.67],
					[214254.9469754.13],
					[214255.6469752.6],
					[214255.7369752.41],
					[214256.57969751.496],
					[214257.369750.72],
					[214258.3669749.67],
					[214258.769749.446],
					[214262.0469747.24],
					[214275.4469739.24],
					[214276.8869738.41],
					[214287.0669732.52],
					[214299.3869724.78],
					[214301.0769723.75],
					[214309.9369720.06],
					[214323.2769714.3],
					[214329.4469711.42],
					[21434069707.71],
					[214343.5969706.37],
					[214345.7969705.74],
					[214351.4169704.5],
					[214358.269702.8],
					[214364.469713.59],
					[214376.0269733.82],
					[214404.6469784.7],
					[214432.6769834.29],
					[214452.8969869.19]
					[214379.82369841.291],
					[214384.24769844.056],
					[214387.02569839.611],
					[214382.60169836.846],
	"properties": {
		"id": 5199540,
		"area": 28443.122295000387,
		"perimeter": 683.4246300438173,
		"versiondate": "2017-08-14T00:00:00.000Z",
		"make": "Natural",
		"descriptivegroup": ["General Surface"],
		"descriptiveterm": ["Agricultural Land"],
		"laFeatureType": "g"
	"id": "84252413-32f8-4700-948a-4a5a3d2c9ace"
I often use JSONlint to fix this stuff manually.
Edit: I have only one rtf sample, but my guess is that the data is always in the last row. So you could read it with a text reader, keep only the last row, remove everything before the first "{", remove all backslashes...
