StringReplacer Doesn't Work? Remove characters before and after
  • January 18, 2022
  • 5 replies
  • 320 views
I have two scenarios; In Column A, I need everything before a set of string, and in Column B, I need everything after a set of string, by using StringReplacer. Below is an example of what I am trying to do:
COUNTY OF PRINCESTON
REGION COUNTIES OF LAMBERSON
Column A:
COUNTY
REGION COUNTIES
Column B:
PRINCESTON
LAMBERSON
in the StringReplacer, I have the expression
^.*\\ OF for everything before
\\ OF ,*$ for everything after
Based on a previous forum https://community.safe.com/s/question/0D54Q000080hTpzSAE/how-can-i-remove-everything-after-in-fme-using-string-replacer
The result of this is that there are no changes to the strings, as everything before and after the ' OF ' remained in the columns.
  • January 18, 2022
Hi @shirley821​ , these expressions could help you. Here, \\b matches boundary of word, \\s* matches zero or more spaces.
.*\\bOF\\b\\s*
\\s*\\bOF\\b.*
  • January 18, 2022
Hi @Takashi Iijima​ Thank you so much, It worked like a charm!! I am wondering where can I find out more about these expressions?
  • January 18, 2022
You can find many sites regarding regular expressions on the Web, but I would recommend you to visit this site, which contains quick start, tutorial, example, detailed reference etc.
Regular-Expresions.info
Note that there are several regular expression flavors and could be slightly different in syntax and functions amongst them in some parts. See the site above to learn more.
I think FME basically uses the PCRE library but am not sure it's version. Hope someone from Safe clarifies this. @danatsafe​
DanAtSafe
Forum|alt.badge.img+18
  • January 29, 2022
@takashi Yes, FME uses Qt which is based on the latest PCRE library.
  • January 29, 2022
Thank you for your clarification, @danatsafe​ ​
