StringPairReplacer with "
  • Aug 15, 2018 1:36 PM UTC
  • 151 views
oliver.morris
Forum|alt.badge.img+14
Hi
I am creating a table using the HTML Report Generator. I have some hyperlinks in my table and the report generator replaces these and it doesnt display correctly in the email that finally gets sent out.
I am using the StringPairReplacer to sort out the < > and & but I am stuck with "
Using this: < < > > & & " """
Doesnt work:
StringPairReplacer: @Tcl2 -- failed to evaluate expression `StringPairReplacer_replace' -- list element in quotes followed by """ instead of space
Doesnt work either.
What is the best way to go about replacing " with "
Many Thanks as always,
Oliver
  • Aug 15, 2018 1:39 PM UTC
Have you tried using a regular StringReplacer for that particular case?
oliver.morris
  • Aug 15, 2018 1:59 PM UTC
that works, thank you David
  • Aug 15, 2018 2:00 PM UTC
Try escaping the literal double quotation in the replacement pairs.
< &lt; > &gt; & &amp; \" &quot;
Alternatively, the TextEncoder (Encoding Type: HTML) could also be helpful.
