String Replacer - Replace consecutive spaces with single space
  • Oct 2, 2014 8:04 PM UTC
  • 272 views
Hello!
I have several fields in a file that contain consecutive spaces. I want to replace the consecutive spaces (generally just 2) with one single space. But I've tried several ways with String Replacer to denote 2 spaces and I can't seem to figure it out. Can anyone help?
Example:
What I have:
123  Main  Street
What I want:
123 Main Street
Best answer by takashi
You are on the right track - StringReplacer. Try this setting to the parameters.
Text to Match: \\s{2,}
Replacement Text:  <invisible, but enter a white space here>
Use Regular Expressions: yes
The expression matches with "two or more consecutive white spaces".
See also these links to learn more about regular expressions.
- FME Workbench Help: Regular Expressions (http://docs.safe.com/fme/html/FME_Workbench/Default.htm#Regular_Expressions.htm)
- Regular-Expressions.info (http://www.regular-expressions.info/)
Takashi
  • Oct 2, 2014 10:43 PM UTC
Takashi
  • Oct 3, 2014 12:26 PM UTC
Got it. Thanks so much!!
tim_wood
Forum|alt.badge.img+8
  • Nov 2, 2017 4:45 PM UTC
