String replacer not replacing
Not understanding why StringReplacer in attached is not working?
Regards,
Richard
  • October 11, 2017
Hi @tfsrichard, in my quick test, the StringReplacer replaced "School" with "" correctly according to your parameters setting. Make sure that the kml_name attribute contain the text "School" including the leading and trailing double quotations.
dustin
Forum|alt.badge.img+36
  • October 11, 2017
What is the result you are expecting?
If you are wanting to remove School from all text, you can remove the quotes around School, and simply leave the Replacement Text box blank.
  • October 11, 2017
Hi @tfsrichard,
Note that some of the records contain "High School" when you remove the quotes as suggested by @caroscro the "High" will be trailing those records.
