String field to Date field
  • Jun 7, 2022 9:59 PM UTC
  • 492 views
I'm trying to separate several years of data based on an install date which is input as a string field.
The data is manually input as a simple string (ie. "2019" no day or month information) and in an effort to keep from having to manually update the entire process at year's end I'm using a test filter with date/time functions that will pull out "Current Year", "Last Year", etc. for several years of data but I'm having trouble getting the string converted to a format that the date/time functions will recognize. I've tried using the string formatter to get the string into a number which I thought would register as a date automatically with FME but that doesn't seem to work either.
Any thoughts? This seems like such a simple issue I can't find a solution for.
ctredinnick
Forum|alt.badge.img+22
  • Jun 8, 2022 5:59 AM UTC
An FME date has form yyyymmdd (also described as %Y%m%d), so it needs a month part and a day part. If a month and day are not provided, then I don't think the DateTimeConverter can default it to something.
I'd use an AttributeCreator, with a Conditional Value to say, if the given 'date' matches regex ^[0-9]{4}$, then add a '0101' 1 January to the end of the string like: @Value(Current Year)0101
If there are more date formats used other than the four digit year, then you'll need to add a different rule for each case.
Once the the numbers are in that yyyymmdd form, then the date functions, writers etc will work with it as if it is a date.
Forum|alt.badge.img+54
  • Jun 8, 2022 9:54 AM UTC
Rather than convert the string to a date, you can convert the current year date to a value of just the year and use that in the test filter, e.g.
