StatisticsCalculator - How does Numeric Count work?
gmbutler2
Forum|alt.badge.img+10
I am trying to use a transformer that will look at a single attribute and return with a value equal to the number of instances that the attribute is being used. I try the numeric count attribute created by a statistics counter, and it appears to be the correct number, but based on the description of the transformer, I am not certain it is going to be the correct method. Can someone explain to me if this is what the statisticscalculator is doing for the numeric count?
gmbutler2
  • June 17, 2016
I misspoke....I meant
I am trying to use a transformer that will look at a single attribute and return with a count value equal to the number of instances that the defined attribute has identical values being used within it.
Numeric Count is the number of features where the selected attribute is a valid integer or floating point value. Empty or null values are not counted.
gmbutler2
  • June 17, 2016
essentially....if a list has an attribute for birth year and the list items are 1980,1980, 1979,1980,1964,1979,1980....then an attribute would be created for each item stating 1980/4, 1980/4, 1979/2,1980/4,1964/1,1979/2,1980/4 (Birth Year Attribute/numeric_count Attribute)
