SSH
  • Mar 2, 2026 2:42 PM UTC
  • 74 views
marionmahot
Forum|alt.badge.img+4
I need to connect to a PostgreSQL database via an SSH connection. How can I do that ?
Thank you
crystalatsafe
Forum|alt.badge.img+32
Hi ​@marionmahot
I don't believe this is currently possible in FME.
One potential option from this community idea: Support database connections over SSH, is to make a local SSH tunnel to the database, and then have FME connect via that tunnel, but I don't believe there is a way to currently create a tunnel in FME.
Do you mind sharing a bit more details about your use case?
