SQLExecutor No Longer Working
  • Aug 26, 2026 5:47 PM UTC
  • 139 views
spawkly
Participant
Forum|alt.badge.img+7
I have a workspace on FME Flow that ultimately creates records in a SQL Server non-spatial database using two SQLExecutor transformers with queries that came directly from the DBA.  I didn’t write the queries and I only basically understand what they do because I’m not a SQL person, but they both are sandwiched between “BEGIN TRANSACTION  → COMMIT” statements.
Up until recently, the SQLExecutor transformers in question used hard-coded server/username etc and it all worked fine.  However, during our most recent FME Flow software update (to 2024, but I don’t think Flow is the problem here as it is present in my Form testing as well) I was informed by our FME administrator that I could no longer use hard-coded server/username details, I had to switch to using an ESRI ArcSDE Geodb connection file to connect to this SQL Server database.
This change worked just fine for other, more simple, Select and Insert sql queries, but these two mentioned above just stopped working.
I confess I find myself completely stumped.  There are no error messages, they simply don’t produce the expected results in the database.  If I switch back to hard-coded passwords, it all works fine again.  The queries haven’t changed and the connection file was created in ArcGIS Pro using the same details.
Can someone point me in the right direction on how to fix this?
veronikaatsafe
Forum|alt.badge.img+13
Hi ​​@spawkly,
Are you able to share your full FME translation log with debug enabled covering the run where the SQLExecutors are meant to write the records? It would be very helpful if you could share your SQL statement as well.
Thank you!
j.botterill
Forum|alt.badge.img+69
  • Aug 27, 2026 11:53 PM UTC
Yes embedded credentials are less secure than database connections. You can make a MS SQL database connection for the existing two SQLexecutors, rather than using ArcSDE connection, which will parse its on SQL code to extract featureclasses.
In the SQLexecutor choose format reader Microsoft SQL Server, then in Connection select Add Database Connection. Enter:
  • Server
  • Database
  • Authentication: either SQL Server Authentication or Windows Authentication
  • If using SQL Server Authentication, also enter Username and Password
You can also create it from Utilities > FME Options > Database Connections > Add. SQL Server connections in FME typically do not require a port unless your setup specifically does.
desiree_at_safe
Forum|alt.badge.img+25
Hi ​@spawkly! ​@j.botterill’s suggestion above is a great option to try, and it aligns with what we generally recommend here. A native Microsoft SQL Server database connection stores your credentials encrypted in FME's connection store, separate from the workspace itself. This should address your admin's security concern well, since it moves you away from hard-coded credentials.
It's also possible the statement you're trying to run isn't supported through that SDE connection layer, even though the underlying SQL Server database would support it just fine through a direct connection. See the note on SQL View Editing in the Writer documentation, since this statement could be running into a similar underlying issue.
If you're willing to share your SQL and the log file, that would help us confirm whether that's what's happening here, or if something else is going on. If you prefer, you could always open a support case with us following this link as well: Support Case 🙂
