SQLCreator SQL statement editor (2018.1) - Copy/paste issue
When copy/pasting SQL code into the SQLCreator SQL statement editor (2018.1) specific characters are replaced by others, e.g. '}' becomes '%7D'. This doesn't happen using the 2017.0 version.
How can I make it work in the 2018.1 version?
Best answer by nampreetatsafe
Update: This issue is resolved and with FME 2020.0 and newer you can copy and past SQL statements.
There's a fix included in the latest FME 2020 beta (b20182). Though it has yet to go through QA, I tested it out and managed to successfully copy and paste SQL containing { } || from Oracle SQL Developer to the SQLCreator.
Please let us know if you have any luck with this.
[internal reference FMEDESKTOP-10005]
  • November 6, 2018
Unfortunately this is a known issue when copy/pasting from certain SQL editors, e.g. SQLDeveloper and DbVisualizer to the FME 2018 editor widget.
You may want to contact Safe support and refer to ticket C138937.
gio
Forum|alt.badge.img+15
  • November 7, 2018
@fkoenig
use notepad.
Copy to notepad from SQL editor and then copy from notepad to SQL_Creator/Executor.
  • November 7, 2018
@david_r Thanks for the answer. I contacted support but there is no further insight re the solution of the issue.
@gio So far I have been using that workaround, but nevertheless thanks for your answer. I just thought to raise the issue as it is an annoying step that shouldn't be necessary with this kind of software.
gio
  • November 7, 2018
@fkoenig
@david_r
WE have reported this issue a while ago.
But yes, very annoying. But we are patient as we love FME !
perry
  • February 14, 2020
FME 2019.2 still has the same problems unfortunately. FME developers: Is there a solution coming soon? (it worked fine in V 2017).
nampreetatsafe
Forum|alt.badge.img+13
  • February 21, 2020
