SQL Executor run a procedure
  • November 20, 2018
  • 280 views
ciarab
Forum|alt.badge.img+9
I have a procedure I want to call from an oracle database
-- In Oracle SQL this would be executed as follows (variables for address_heading and address id must be declared):
execute clar.clar.get_address_model_building(38660795,
address_headings,
address);
Im using the sql executor but cant seem to get it to run successfully. It should return a value like this
BN 1T 1L C*
DAVIS COURT, MAIN STREET, HEADFORD, CO. GALWAY
I have tried various iterations but just keep getting did not succeed; error was `ORA-00900: invalid SQL statement'
Any advice on what I need to pass in to run the procedure and return a result?
Thanks
erik_jan
Forum|alt.badge.img+19
  • November 20, 2018
Hi Ciara,
I have had the same issue.
The SQLExecutor can not handle Oracle PL/SQL out parameters to populate an attribute.
I have solved this by creating a Stored Function instead of a stored Procedure.
The Stored Function can be called inside a SQL statement and the resulting value can be used as an attribute.
Hope this helps.
Erik
ciarab
  • November 20, 2018
@erik_jan Thanks so much for your quick response. I was going through multiple methods that usually work for me but getting nowhere. That sounds like a good solution for me
Ciara
  • February 22, 2019
erik_jan wrote:
Hi Ciara,
Hope this helps.
Erik
can you please some piece of a code as an example? I having the same issue and not getting anywhere.
Here is a test I set up for you Gauripearl:
ORACLE Setup:
CREATE TABLE test_table_for_function(
id NUMBER PRIMARY KEY NOT NULL
,txt_column VARCHAR2(20)
,num_column NUMBER
INSERT INTO test_table_for_function(id, txt_column, num_column)
VALUES (1, 'test text value 1', 123456);
VALUES (2, 'test text value 2', 123457);
VALUES (3, 'test text value 3', 123458);
Create a Function:
CREATE OR REPLACE FUNCTION fn_get_val(p_id IN NUMBER)
RETURN NUMBER IS
v_num_value NUMBER;
BEGIN
SELECT num_column
INTO v_num_value
FROM test_table_for_function a
WHERE a.id = p_id;
RETURN (v_num_value);
END;
In your SQL Executor:
FME_SQL_DELIMITER ;
select fn_get_val(1) return_value
from dual;
This will return your function result which I have aliased to an attribute called RETURN_VALUE
