SQL Executor Provider error `(-2147217843) Login Failed
  • Oct 12, 2018 8:22 PM UTC
  • 107 views
Microsoft SQL Server Spatial Reader: Connection failed. on SQL Executor even though a Reader with the exact same parameters works without issue.
stalknecht
Forum|alt.badge.img+22
  • Oct 13, 2018 6:55 AM UTC
Did you try the Non-spatial version. Is it really a spatial table you are trying to query? Did you also try the JDBC-driver?
