SQL Executor - Microsoft SQL Spatial
  • Oct 24, 2016 8:02 AM UTC
  • 6 replies
  • 71 views
Hello,
can someone please help me to understand this error:
ERROR |Microsoft SQL Server Spatial Reader: Failed to fetch post-ADO SQL Server columns for table
I can't replicate it every time I run my workspace. But when I capture that, the process ran and I got expected results.
Thanks
steveatsafe
Forum|alt.badge.img+16
Hi @honkovam, I'm not certain what it is - but if you see it again perhaps send your full log file (and workspace if you can) to support and we can take a look. We might be able to identify where it is failing and from there connect you to the cause.
  • Oct 25, 2016 7:48 AM UTC
@SteveAtSafe
Hi Steve, I would prefer not to share my workspace publicly. Could I please send it to you privately? Many thanks
  • Oct 25, 2016 8:14 AM UTC
@SteveAtSafe
You can open a support case directly with Safe here: https://support.safe.com/knowledgeSubmitCase?
steveatsafe
@SteveAtSafe
Yes! @david_r Thank you! @honkovam I did mean mean for you to submit a workspace via our Support... David has nicely pointed you to the link.
  • Oct 26, 2016 9:40 AM UTC
hi @SteveAtSafe, @david_r,
thank you both! A ticket has been logged and I have someone looking into it already.
kjetilpettersso
I am seeing the same error, although it doesn't seem to actually do anything. Was there ever a conclustion to the support case that was created?
