Splitting .las
  • Nov 6, 2024 3:21 PM UTC
  • 13 replies
  • 323 views
bmwhbmwh
Forum|alt.badge.img+4
Hello, my previous post was not well Described apparently,
i need to split .las just like that.
please if you suggest any workflow do describe it a little more than just the name of transformer as that is usless for me (i dont really know how to use FME)
Best answer by hkingsbury
I’ve attached a workspace (2024.1) that will split the input LAS into a number of areas (using the iterate snipper) then generate some clipping areas and then clip the LAS to those areas.
This is assuming that your LAS is following a linear area such as a road or rail corridor
danilo_fme
Forum|alt.badge.img+58
  • Nov 6, 2024 7:41 PM UTC
Hi @bmwhbmwh
Do you have too these area geometry like the picture?
bmwhbmwh
  • Nov 11, 2024 7:37 AM UTC
 i dont have any areas or nothing, i edited the red zones in on the picture
i know that tiler can do that however im more interested in splitting it in the way i show in the picture above.
hkingsbury
Forum|alt.badge.img+73
  • Nov 12, 2024 8:30 PM UTC
bmwhbmwh
  • Nov 13, 2024 7:28 AM UTC
hkingsbury you sir are a genious
bmwhbmwh
  • Nov 19, 2024 11:39 AM UTC
hkingsbury
if you could help me further i have a question about updating the segments that come from the resoult of that split.
What i mean:
i want to take these 2 as example
and make a Break zone that is ca 10m, in that zone everything must be deleted.
than insert them back in with a new file
To Summerise:
Imagine a tunnel or an area that is initially scanned. Over time, the area undergoes changes and needs to be rescanned. However, the focus is solely on identifying and capturing the newly changed parts.
if there is a better way of doing it im happy to hear your take on it.
hkingsbury
  • Nov 20, 2024 7:47 PM UTC
You can use the clipper to remove that section from the existing data and then the pointcloudcombiner to combine the new scan data with the existing
bmwhbmwh
  • Nov 21, 2024 10:34 AM UTC
hkingsbury
How should i do it?
i have now separated these two.
but should i create a new box and cut that out?
bmwhbmwh
  • Nov 21, 2024 12:50 PM UTC
hkingsbury
so i have played with it for a while and i got this as a resoult.
it did make a separation in the middle but it was tottaly random/dumb luck. how can i controll where i cut better?
say i want to be speciffic and cut the ends of the tunell or 70% of it.
Thank you for the support so far.
hkingsbury
  • Nov 21, 2024 7:21 PM UTC
I would assume you have an asset dataset that defines where the tunnel is. Using that, buffer the tunnel (turn off end caps) and use the resulting polygon to clip out the old data. Clip the new data to ensure you have that in same extent then combine the new data into the old.
OR
if you have the new data, generate the bounds of the data (use the first part of the workbench I initially shared) then use that to clip out the old data and then combine the two data sets
bmwhbmwh
  • Nov 25, 2024 7:14 AM UTC
hkingsbury
i have tried and this is what happens.
When i use the first part of your script i get simple lines.
the first part of your script makes only line ant not the area no? so that cannot be used as Clipper?
i thouth this was supposed to happen.
  1. New data
  2. make lines (first part of your script)
  3. Create Box in middle (5m each side)
  4. Delete
  5. Replace
hkingsbury
  • Nov 26, 2024 9:23 PM UTC
You need to then buffer them to create the polygons for the clipper. Make sure you set End Cap Style to None.
From your screenshot its not clear if you’re doing this on the new data. You want to be doing this step on the new data to insert into the existing data. This will create a polygon to clip the extent of the new data out of the old data, therefore removing any overlaps
bmwhbmwh
  • Nov 27, 2024 8:52 AM UTC
hkingsbury
i think im confused, sorry for that.
i struggle to figure out what to do with the bufferer, look….
whenever i run it it gives me same resoult as Hull replacer. so i dont get the point with it
All i really need now is just a way of creating a segment/polygon that will be used in the cutter.
hkingsbury
  • Nov 27, 2024 6:51 PM UTC
Hypothetically, you have an existing scan of a rail corridor, that corridor passes through a tunnel. The tunnel has been re-scanned recently and you want to remove the old tunnel data and replace it with the new scan.
The original workbench has logic in then that will generate a rough centreline for that scan. To remove the old tunnel data you need to buffer that centreline to generate an area that can be used as a clipper. The hull replacer output could be used, but you’ll likely also need to buffer that.
Now that you have an area that covers the bound of your new tunnel scan you can use that to clip out the tunnel data from the existing scan of the corridor.
Next, you can use the pointcloudcombiner to combine the new tunnel scan with the rest of the scan for the corridor
