Split road network with other road network (Attribute networks)
I have a (complete) road network containing all the "real" roads segments of the road network. I then have several "copies" of the road network but with different segments, these segments define attribute properties for the road segments. I want to split the "real" segments by multiple attribute segments.
e.g.:
Road 1
 5m                      10m
 70km/h                 50km/h        70km/h
Desired output:
5m           10m          10m          10m
70km        70km        50km/h       70km/h
Does anyone have a good solution for performing this in FME?
Best answer by geomancer
The LineOnLineOverlayer, with parameter 'Accumulation Mode' set to 'Merge Attributes'.
LineOnLineOverlayer_Demo
geomancer
Forum|alt.badge.img+57
  • August 12, 2022
  • August 18, 2022
Thanks, LineOnLineOverlayer solved my issue perfectly. It also handled more than two tables as was required. The _overlaps attribute helped me keep track of which segments overlapped from > 2 tables.
