split polygons at dateline
Hello,
I have a polygon that crosses the dateline.
I would like to split it into two at the dateline, so I even won't need a dateline fix (e.g.https://knowledge.safe.com/articles/34013/dateline-problem.html). My goal is a longitude within -180 and 180 and a correct display on the map using LL-WGS84.
Is this possible? What transformers do I need to use?
jdh
Forum|alt.badge.img+41
  • April 19, 2017
One option would be to use the clipper with a clipper feature being a box -90, 90,-180,180. Make sure create aggregates is set to No, and you want the features from both the Inside and Outside ports.
erik_jan
Forum|alt.badge.img+26
  • April 19, 2017
Another way would be to use the InterSector to Cut the area and an AreaBuilder to restore the 2 polygons:
With this result:
jdh
  • April 19, 2017
With this result:
With the caveat that they must be simple polygon(s) with no holes or slivers, and you'll need to transfer the attributes if required.
