I have a single county parcel (polygon) .shp file that I need to break into several .shp files based on the value in the CITY field. That is if there are 25 cities in a particular county then I will have 25 resulting .shp files.
Split a single input into several outputs based on attribute value
Login to the community
No account yet? Create an account
An FME Account is required to contribute
LoginEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
