split a row into multiple rows by a field with delimited values
  • October 20, 2016
  • 318 views
Hi, my table has a Owner field with multiple values delimited by either ; or &. Please see below table 1 for an example.. How to split the first and the third rows into multiple rows so the result like the table2?
Table 1:
TractIDOwner123312Jim, Jones; Maria, Jones
32141Alex, Bulman312312Russel, Terry & John, Stockton
Table 2:
TractIDOwner123312Jim, Jones123312Maria, Jones32141Alex, Bulman312312Russel, Terry312312John Stockton
Best answer by ebygomm
An AttributeSplitter followed by a list exploder will do this. If you want to split by multiple attributes it's probably best to replace the ampersand with a semi colon using a string replacer prior to using the attribute splitter
Forum|alt.badge.img+39
  • October 20, 2016
  • October 20, 2016
Thanks for the diagram. Works perfect!
