Spike Remover - says invalid geometry
  • Jan 5, 2026 12:06 PM UTC
  • 36 views
couch
Forum|alt.badge.img+7
Hi, I have set the spike remover to 3D dimensions to read 3D solids however everything is being rejected due to - ‘Invalid Geometry Types’. Any ideas?
  • Jan 5, 2026 12:38 PM UTC
If I’m reading the documentation correctly, the SpikeRemover does not support solids:
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/spikeremover.htm
“The SpikeRemover receives features with line, path, or area geometry [...]”
