Special characters in FME textstroker
  • July 18, 2013
  • 92 views
I am trying to stroke the following string "ABCD  \\n - 01234" using a textstroker in FME. However after stroking the text, the newline character (\\n) is not interpreted as a new line. Instead it is stroked as plain text.
How to stroke text which has special characters in FME?
Regards,
Ananda
Best answer by david_r
it is possible that the TextStroker doesn't support newlines. I suggest you write Safe to verify, and perhaps also to file a feature request.
David
  • July 18, 2013
David
