SpatialFilter fails all records
  • Feb 23, 2026 8:25 PM UTC
  • 119 views
hriordan
Forum|alt.badge.img+12
I have a simple job reads points from a spreadsheet and buffers my pipeline. I would like to set up the SpatialFilter to see which points on the spreadsheet are outside my buffer.  For some reason, all points go to the Failed port. I have exported the buffer that is created and verified they correct and most of the points fall within the buffers.  Any tips are appreciated!
Best answer by hriordan
I just got off of the phone with a resident expert...Even though my “testing” by exporting the reviewing the files in Pro showed they should be falling within my buffers, they actually were not.  It had to do with the projection we use that is not very common.  We were able to use the ProjReprojector before I created the buffer to get them lined up correctly.
dustin
Forum|alt.badge.img+36
  • Feb 23, 2026 8:26 PM UTC
Make sure both datasets are in the same projection.
hriordan
  • Feb 23, 2026 8:35 PM UTC
Thanks.  I did that with a coordinate setter.  I also wrote both datasets out to ensure most points did fall within the newly created buffer.
DanAtSafe
Forum|alt.badge.img+23
  • Feb 23, 2026 10:09 PM UTC
Hi ​@hriordan Do you get the same result with a SpatialRelator or a PointOnAreaOverlayer?
hriordan
  • Feb 23, 2026 10:19 PM UTC
