Spatial Relator: List issues with multiple suppliers and multiple predicates
  • Oct 6, 2022 11:04 AM UTC
  • 210 views
markcoopersdc
Hi
I am using fme to work out the spatial relationship between two polygon datasets. Some requesters will have multiple suppliers and I have enabled the list to store the references for each supplier. Following this transformer, I have use a list concatenator to show these references in one field.
This works great when I have only one predicate selected. Where multiple are selected, I have created a second list concatenator for the relationships{}.pass{}. Unfortunately, both these can contain different number of values. For example, there could be two suppliers, but one of these could pass intersect and within and the other just intersect. My difficulty id knowing which pass attribute relates to which supplier.
Please can someone let me know what I am doing wrong?
Many thanks
@markcoopersdc​ can you attach a small sample dataset and workspace that illustrates the issue and also an image or example of the output you want?
