Spatial join in 3D, Points within Solids
  • May 22, 2024 10:19 PM UTC
  • 151 views
riplizard
I have a segmented column (basically stacked barrels of varying height) and 3D points “floating” within that column. How can I join the points to their containing segments? I made a few attempts but the results suggest FME only checks for X/Y and not Z.
By join I mean the solids acquiring their corresponding points’ attributes, looks like the weird “x-on-x-overlayer”, etc, transformer names unfortunately survived the overhaul 😒
(unrelated: signing up with a too long username gives a wrong “not allowed characters” error in the sign up form)
itsmatt
Forum|alt.badge.img+48
  • May 27, 2024 10:15 AM UTC
So one way which might work is to use the Clipper - The clipper works in 3D and works on solids.
One approach should be to create a 3DBuffer of the points with the bufferer - use sometime like 0.01 as the raduis to make sure it’s still nice and small.
Feed in the Column sections into the Candidate port of a clipper and the points into the Clipper port.
Attached is an example with dummy data:
