Spatial filter performance
  • Jun 16, 2015 7:33 AM UTC
  • 6 replies
  • 133 views
Dear All ,
We face a performance issue in spatial filter when both candiate and filter having more than 150K , as shown below , it is taken more than 2 days and still running . below is part to the log files
2015-06-16 11:11:48|168167.0|  7.0|INFORM|SpatialFilter_13(SpatialFilterFactory): Processed 'Candidate' 118233 / 150608
2015-06-16 11:11:56|168174.1|  7.2|INFORM|SpatialFilter_13(SpatialFilterFactory): Processed 'Candidate' 118236 / 150608
2015-06-16 11:12:01|168179.0|  4.9|INFORM|SpatialFilter_13(SpatialFilterFactory): Processed 'Candidate' 118242 / 150608
2015-06-16 11:12:06|168183.9|  4.9|INFORM|SpatialFilter_13(SpatialFilterFactory): Processed 'Candidate' 118243 / 150608
2015-06-16 11:12:11|168188.2|  4.3|INFORM|SpatialFilter_13(SpatialFilterFactory): Processed 'Candidate' 118255 / 150608
Best answer by takashi
Hi @annachukicheva, Regarding the original question, I assumed that the filter and candidates geometries are areas. In your case, both geometries are points, so I think that you can omit the step 1,2 and 5-7.
  • Jun 16, 2015 2:19 PM UTC
How about tiling the features so that the processing would be divided into groups?
(1) Add a unique ID attribute to the candidates.
(2) Extract geometry as an attribute for each candidate (GeometryExtractor).
(3) Send both filters and candidates to a Tiler.
(4) Separate the tiled filters and candidates, send them to the SpatialFilter. Set tile column and row attributes to the "Group By" parameter.
(5) Select unique Passed features using the DuplicateRemover (Key Attribute = ID attribute of candidate).
(7) Restore the original geometry (GeometryReplacer).
The optimal number of tiles is unknown but I expect 10x10 - 20x20 would be effective.
Takashi
gio
Forum|alt.badge.img+15
  • Jun 17, 2015 1:17 PM UTC
The tiling strategy has as perk that you can use the parallelprocessing option (because of the group by for one)
Should yield (albeit maybe slight) performence gain.
  • Jun 18, 2015 5:25 AM UTC
thanks for the supports , I will check it and let you know .
Hello, @takashi,
first of all, thank you a lot for all your good advices you gave in this share point.
have a question to your process, you wrote here.
First, to my process: I need to check: points objects with another point objects (if they are equal or not). So i made as in your list written until the step Nr. 4.
With step 5 and 7 i m not so sure if i need them to complete. Can you please explain me what for you do these steps? Are they needed in my process, u think?
Thanks,
Anna
  • Jan 27, 2016 10:03 AM UTC
Thank you @takashi a lot!
