Spatailfilter different behaviour (script vs. application)
geobiker
my workbench use the Spatialfilter to detect if features from ESRI Geodatabase are inside a polygon.
Candidate: 10 featureclasses (diffrent geometry) from ESRI Geodatebase
Filter: 1 Polygon from File-Geodatebase.
With FME 2016.1.3 and Windows Server 2008 the workbench works fine. Now I have switched operating yystem to Windows Server 2016 and FME Desktop to 2018.1.
And now I have the problem that the SpatialFilter only works if I run the workbench in the FME application. If I use a script to start the workbench via par-file no feature will pass against the filter.
Kind regards
Stefan
Forum|alt.badge.img+50
Are you absolutely sure you're using the same parameters? I know this seems like a very obvious thing but I can assure you it's happened to me multiple times.
fmelizard
Forum|alt.badge.img+19
  • December 6, 2018
I'd carefully examine the log file of both to see where things diverge.
gmbutler2
Forum|alt.badge.img+10
  • December 6, 2018
I would also verify that both objects coming into the spatialfilter are at the same coordinate system. Another obvious thing but something that can be easily overlooked.
geobiker
  • December 6, 2018
in the meantime I have replaced SpatialFilter instead of Feature Reader. Now I get the excepected results with script and application.
A nice benefit of this change is the workbench looks much simpler and the performance is also better than before.
Kind reagards
Stefan
