Sorter - simple question - Mode Natural
  • Sep 10, 2021 1:35 PM UTC
  • 5 replies
  • 112 views
connecter
Forum|alt.badge.img+10
today I get a little bit of confused by the new Sorter Mode "Natural":
SorterPlease, can somebody explain me, why the Mode Natural work like this?
Thanks!
Best answer by danminneyatsaf
Thanks @Mark Stoakes​ for your answer. But when I have the same number like above in the screenshot, why is it not equal and the second attribute will sort the table?
It seams like 1.5.10 is != 1.5.10 in Natural Mode.
Hi @connecter​, thank you for bringing this bug to our attention! I have filed an issue in our tracking system that the developers will try and fix. If you're interested, the issue tracking code is FMEENGINE-70765.
@connecter​ Natural tries to combine the best of alpha and numeric sort. In alpha sort, if you have:
2 street name
11 street name
the alpha sort will give you:
11 street name
2 street name
but Natural will return :
2 street name
11 street name
plus a few other additions described in the user docs. under Sorting Attributes. Also wikipedia explains it.
connecter
  • Sep 10, 2021 4:27 PM UTC
2 street name
11 street name
11 street name
2 street name
2 street name
11 street name
Forum|alt.badge.img+63
That's certainly odd. Can you just doublecheck and make sure there's no trailing space in either of those values?
connecter
  • Sep 13, 2021 3:04 PM UTC
@Hans van der Maarel​ , thanks for your reply. I make a bugreport from it. I create a new workflow for the bugreport. If someone would like to test the workflow. My result from Sorter with Natural Mode:sorter_resultYou can easily switch in the Transformer Sorter to Numeric an all is fine.
danminneyatsaf
Forum|alt.badge.img+13
