Some polygons disappear with dissolver.
  • Dec 21, 2016 8:06 PM UTC
  • 13 replies
  • 127 views
Hello!
Some polygons disappear in the transformer dissolver, it doesn´t matter if I use group by or not.
Coordinaterounder, Densifier, Snapper fix some problem but other polygons disappear instead.
Geometry validator with no result.
Tips or idea?
nielsgerrits
Forum|alt.badge.img+67
What exact version of FME?
Can you share the geometry so we can reproduce the error? Just strip the attributes and write to FFS.
You can easily anonymize the features with an offsetter and rotator if needed.
itay
Forum|alt.badge.img+19
  • Dec 22, 2016 7:28 AM UTC
The all point of the Dissolver is to dissolve polygons and therefore make some 'disappear', can you visualize your unexpected results and share it?
  • Dec 22, 2016 8:14 AM UTC
Here is a screenshot and input file for this example...
small-example3-mergeid.zip
Try to dissolve with group by for the attribute mergeid...
itay
  • Dec 22, 2016 8:21 AM UTC
My guess is that there are inconsistencies between the features, especially mis-alignement of nodes, possibly using a coordinaterounder before the dissolver might help.
  • Dec 22, 2016 9:53 AM UTC
It works sometimes with coordinaterounder. But polygons disappear elsewhere. Very frustrating!
  • Dec 22, 2016 9:56 AM UTC
FME 2016.1.1 - 64bit
FME 2016.1 - 32bitFME 2015.0 - 32bit
FME 2015.1.1 - 64bit
itay
  • Dec 22, 2016 10:23 AM UTC
I can imagine....I would suggest contacting support
  • Jan 3, 2017 8:31 AM UTC
Is it possible that some of your polygons contains arcs?
I've seen quite a lot of similar bugs on datasets containing arcs, probably due to floating point precision issues.
Consider pre-processing your data with an ArcStroker and a Snapper (segment snapping) before the Dissolver.
fmelizard
Forum|alt.badge.img+22
  • Jan 4, 2017 7:35 AM UTC
@sjodin
I can advise that we made massive improvements in this area in FME 2017. Please try the original dissolves with FME 2017 beta and let us know at support@safe.com if there are still issues. @david_r - you'll be pleased to know that the improvements also included robustness in arc situations, so there should be no need for stroking and snapping prior to dissolve.
  • Jan 4, 2017 8:17 AM UTC
@sjodin
Thanks Dale, that's great news!
Forum|alt.badge.img+7
@sjodin
That's great news!
We have also experienced quite some issues with polygons disappearing when using the dissolver. Looking forward for FME 2017!!
gio
Forum|alt.badge.img+15
  • Jan 4, 2017 3:41 PM UTC
@sjodin
Both areas in the sample have huge spikes...
If you use spikeremover at max 1 degree, the output will dissolve correctly.
fmelizard
  • Jan 4, 2017 9:33 PM UTC
That's great news!
We are hopeful that most issues will be one with FME 2017, but that said, we have a final step we will introduce in FME 2018 that will end this problem we hope for good. In FME 2017 in some really bad cases you need to do a snapping first, but my understanding is that we know of no cases where a first snapping followed by dissolve has issues in FME 2017
