snip each line from known point even the line overlap later
  • Jun 8, 2020 10:41 PM UTC
  • 5 replies
  • 76 views
could someone help me ,how could i isolate paths perfectly to from common node ,each line starts from this known node till end of the line ,so how could i solate although lines overlapped overlapped and has a common node .thanks in advance
at the end i need to seperate each path with the own network id from the point any idea , i will be thankful
i tried the whole day to do it ,but i did not success , i hope some one can help me
Thanks in advance
danilo_fme
Forum|alt.badge.img+58
  • Jun 10, 2020 2:17 AM UTC
Hi @dina_dodo
Did you use the transformer TopologyBuilder in the lines to create nodes ( begin and end of lines ) ?
Thanks,
Danilo
  • Jun 10, 2020 6:24 AM UTC
Hi @dina_dodo
Thanks,
Danilo
i used it ,the line should start from the point as shown as picture till end of line and each line has his own id . but i found topology builder ,clean data yes ,create extra node at the two lines overlapped on the left . exactly this two lines occure problem when i use buffer for isolating .
is it possible to delete the extra noded at over lapped or move one line that overlapped a little bit .
which method suggested you to isolate paths
could i use snipper from the known point till 70 percentage of each line depend on the length ?
.Thanks for reply
danilo_fme
  • Jun 10, 2020 10:41 AM UTC
.Thanks for reply
Hi
Could you share a sample of data?
  • Jun 10, 2020 4:13 PM UTC
Hi
could i ask how could i extract sample of data bcs it is too big to share ,if i want to extract only sample of my problem .how could i do that and thanks
danilo_fme
  • Jun 11, 2020 3:56 PM UTC
You can open the data in FME Data Inspector, select the lines that you want and save as data:
1) File -> Save Seleted Data as:
2) Format: FME Feature Store ( FFS ) or another format.
Thanks in Advance,
Danilo
