Snap polygon to polyline
  • Mar 19, 2014 9:57 AM UTC
  • 5 replies
  • 144 views
i made a tester to snap line to frame,
but how to snap polygons to that frame, because anchor snaper failed in process.. i try build lines from polygons, but problem is in the donut polygons, they dont build all polygons..
  • Mar 19, 2014 10:20 AM UTC
which "snapping type" have you configured for the AnchoredSnapper? You might have to use Segment snapping (FME 2014+ only) if the vertices of the polygon and the frame are too far apart.
David
gio
Forum|alt.badge.img+15
  • Mar 19, 2014 2:30 PM UTC
Hi, i made a workbench doing that.
It snaps a polygon wether its donut or not, to targetpolygon by 1 vertex.
Il put on chatter.
  • Mar 24, 2014 7:36 AM UTC
tnx, but i have FME 2012, i can't open this. can you save it in 2012?
gio
  • Mar 24, 2014 12:50 PM UTC
Hi Nika,
I only have fme 2013 and 2014 available.
I made a print with all the annotations opened.
Should be easy to make a 2012 of it, it's only slightly different form yours, mainly concerning the donuts.
Grteets Gio
gio
  • Mar 24, 2014 12:51 PM UTC
...bit more zoomed in
