.skp to 3D PDF is not working
  • Feb 5, 2018 3:34 PM UTC
  • 139 views
I have downloaded a 3D Sketchup model from Sketchup warehouse and trying to convert it into 3D pdf ... A blank pdf file is resulted..
Execution Summery:
Starting translation...
FME 2017.1.0.0 (20170731 - Build 17539 - WIN64)
FME_HOME is 'C:\\Program Files\\FME\\'
FME Database Edition (node locked-crc)
Serial Number: 0
Temporary License: 30 days left.
Machine host name is: Anuj-PC
START - ProcessID: 8816, peak process memory usage: 31788 kB, current process memory usage: 31720 kB
FME Configuration: Command line arguments are `C:\\Program Files\\FME\\fme.exe' `C:\\Users\\Anuj\\AppData\\Local\\Temp\\wb-xlate-1517680516554_10516' `LOG_STANDARDOUT' `YES' `LogCountServerName' `{e9a3db67-8fcd-4a27-88f3-14e3fc738201}'
Shared folders for formats are : C:\\Program Files\\FME\\datasources;C:\\Users\\Anuj\\Documents\\FME\\Formats
Shared folders for transformers are : C:\\Program Files\\FME\\transformers;C:\\Users\\Anuj\\Documents\\FME\\Transformers
Shared folders for coordinate systems are : C:\\Users\\Anuj\\Documents\\FME\\CoordinateSystems
Shared folders for coordinate system exceptions are : C:\\Users\\Anuj\\Documents\\FME\\CoordinateSystemExceptions
Shared folders for coordinate system grid overrides are : C:\\Users\\Anuj\\Documents\\FME\\CoordinateSystemGridOverrides
Shared folders for CS-MAP transformation exceptions are : C:\\Users\\Anuj\\Documents\\FME\\CsmapTransformationExceptions
Shared folders for transformer categories are : C:\\Users\\Anuj\\Documents\\FME\\TransformerCategories
FME Configuration: Reader Keyword is `SKP_1'
FME Configuration: Writer Keyword is `MULTI_WRITER'
FME Configuration: Writer Group Definition Keyword is `MULTI_WRITER_DEF'
FME Configuration: Reader type is `SKP'
FME Configuration: Writer type is `MULTI_WRITER'
FME Configuration: No destination coordinate system set
FME Configuration: Current working folder is `C:\\Users\\Anuj\\AppData\\Local\\Temp'
FME Configuration: Temporary folder is `C:\\Users\\Anuj\\AppData\\Local\\Temp', set from environment variable `TEMP'
FME Configuration: FME_HOME is `C:\\Program Files\\FME\\'
FME Configuration: FME_BASE is 'no'
FME Configuration: FME_MF_DIR is 'C:\\Users\\Anuj\\AppData\\Local\\Temp/'
FME Configuration: FME_MF_NAME is 'wb-xlate-1517680516554_10516'
FME Configuration: FME_PRODUCT_NAME is 'FME(R) 2017.1.0.0'
System Status: 4.48 GB of disk space available in the FME temporary folder (C:\\Users\\Anuj\\AppData\\Local\\Temp)
System Status: 8.00 TB of virtual memory available
Operating System: Microsoft Windows 7 64-bit (Build 7600)
FME Platform: WIN64
Locale: en_US
Code Page: 1252 (ANSI - Latin I)
FME Configuration: Process limit is 11.90 GB of physical memory
FME Configuration: Start freeing memory when process usage exceeds 35.71 GB of virtual memory
FME Configuration: Stop freeing memory when process usage is below 26.78 GB of virtual memory
Creating writer for format:
Creating reader for format: Trimble SketchUp
Trying to find a DYNAMIC plugin for reader named `SKP'
Loaded module 'SKP' from file 'C:\\Program Files\\FME\\plugins/skp/skp.dll'
FME API version of module 'SKP' matches current internal version (3.8 20170315)
Opening Trimble Sketchup reader
SketchUp Reader: Read Hidden Geometry: 'Auto'
SketchUp Reader: Color by Layer: 'Auto'
SketchUp Reader: Read Edges: 'No'
Using MultiWriter with keyword `MULTI_WRITER' to output data (ID_ATTRIBUTE is `multi_writer_id')
Writer output will be ordered by value of multi_writer_id
Loaded module 'LogCount_func' from file 'C:\\Program Files\\FME\\plugins/LogCount_func.dll'
FME API version of module 'LogCount_func' matches current internal version (3.8 20170315)
FME Configuration: Source coordinate system for reader SKP_1[SKP] set to `SKP_COORDSYS_0' as read from input data
Coordinate System `SKP_COORDSYS_0' parameters: CS_NAME=`SKP_COORDSYS_0' DT_NAME=`WGS84' ORG_LAT=`27.175023' ORG_LNG=`78.042102' PROJ=`AZMED' QUAD=`1' UNIT=`INCH'
Creating writer for format: Adobe 3D PDF
Trying to find a DYNAMIC plugin for writer named `PDF'
Loaded module 'PDF' from file 'C:\\Program Files\\FME\\plugins/pdf/pdf.dll'
FME API version of module 'PDF' matches current internal version (3.8 20170315)
Writer `PDF_1' of type `PDF' using group definition keyword `PDF_1_DEF'
Creating writer for format: Adobe Product Representation Compact (PRC)
Trying to find a DYNAMIC plugin for writer named `PRC'
Loaded module 'PRC' from file 'C:\\Program Files\\FME\\plugins/PRC.dll'
FME API version of module 'PRC' matches current internal version (3.8 20170315)
FME Configuration: Destination coordinate system set to input coordinate system `SKP_COORDSYS_0'
Emptying factory pipeline
Router and Unexpected Input Remover(RoutingFactory): Tested 1 input feature(s), wrote 1 output feature(s): 1 matched merge filters, 1 were routed to output, 0 could not be routed.
Unexpected Input Remover Nuker(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
Taj+Mahal+by+Denoall+v2 (SKP_1) Splitter(TeeFactory): Cloned 1 input feature(s) into 1 output feature(s)
Taj+Mahal+by+Denoall+v2_SKP_1 Feature Counter -1 4(TeeFactory): Cloned 1 input feature(s) into 1 output feature(s)
Destination Feature Type Routing Correlator(RoutingFactory): Tested 1 input feature(s), wrote 1 output feature(s): 0 matched merge filters, 1 were routed to output, 0 could not be routed.
Final Output Nuker(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
Writer `PDF_1' of type `PRC' using group definition keyword `PDF_1_DEF'
PRC Writer: Setting root node name to 'Taj'
PRC Writer: Encountered two-sided surface; auto-picking best surface to write. If this operation is undesired, consider splitting surfaces explicitly
... Last line repeated 1293 times ...
Feature output statistics for `PRC' writer using keyword `PDF_1':
Features Written
Taj+Mahal+by+Denoall+v2 1
Total Features Written 1
Feature output statistics for `PDF' writer using keyword `PDF_1':
Features Written
Features Read Summary
Total Features Read 1
Features Written Summary
Translation was SUCCESSFUL with 2 warning(s) (1 feature(s) output)
FME Session Duration: 18.4 seconds. (CPU: 15.4s user, 1.9s system)
END - ProcessID: 8816, peak process memory usage: 527080 kB, current process memory usage: 137352 kB
LizAtSafe
Forum|alt.badge.img+27
  • Feb 15, 2018 12:17 AM UTC
Hi @anujtiwariiitr,
Did you use a PDFPageFormatter before your PDF writer?
Check out the Creating PDF Cartographic Output tutorial. Also sharing a screenshot or your actual workspace can help the community identify where the problem is.
-Liz
gio
Forum|alt.badge.img+15
  • Feb 15, 2018 4:59 PM UTC
@anujtiwariiitr
I tried it out it works fine and no formatter is needed.
But fme only works with skp version 2015 and earlier. (at least the 2106 fme I currently use)
Check the reader and writer, which can be accessed trough safe site.
At the warehouse you can download 2014 to 2018. So get the 2015 version.
gio
  • Feb 15, 2018 5:05 PM UTC
@anujtiwariiitr
@anujtiwariiitr
I tried qa couple of the Taj Mahal.
They were all post 2015 skp version.
On the main page models you have a version choice. On the Taj Mahal files I did't see that choice.
gio
  • Feb 15, 2018 5:10 PM UTC
@anujtiwariiitr
@anujtiwariiitr
..wait..you did rotate pdf in 3D I hope? (had to ask ;))
