I am using FME to write a Sketchup files with a combination of different elements. Is there a way to define layers with FME in a sketchup file?
I examined a sketchup file with layers using the logger in FME and it looks like the GeometryTrait "sketchup_layer_name" is used define the layer of the object. But when I add this attribute to my translation the objects are not placed on different layers. They all still end up on Layer 0.
<strong>This post is closed to further activity.</strong><br />
It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br />
If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br />
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
