simplifying a pointcloud by 3dgrid
  • Jun 3, 2025 3:45 PM UTC
  • 145 views
koenvdw
Forum|alt.badge.img+7
Hi
I have a point cloud that I want to simplify. I need 1 point in every 1cmx1cmx1cm space/voxel.
I already did something similar, but that was in 2D with point clouds containing only ground points and with the resulting point cloud as some sort of DTM.
In short, I used the 2dgridaccumulator to make a grid. Then I calculated the mean Z value’s of al points in a grid tile and added that value to the centerpoint of that grid. Than I used the vertexcreator to make the new point cloud.
Now I need to do ‘kind of’ the same thing but in a 3D grid…
I was looking at some transformers: pointcloudduplicateremover, pointcloudsimplifier, pointcloudspatialthinner, 3dboundingboxreplacer…
I haven’t found a really good way to do this. Anyone with ideas?
Best answer by takashi
Hi ​@koenvdw ,
PointCloudSpatialThinner from FME Hub might help you.
  • Jun 4, 2025 12:27 AM UTC
Hi ​@koenvdw ,
koenvdw
  • Jun 5, 2025 2:07 PM UTC
Yes, the spatialthinner looks like a viable solution.
I also tried the pointcloudsimplifier, but it’s so heavy on my machine that it crashes FME.
The input is a 7GB point cloud with around 365 million points.
My machine is a i9 11900 with 8 cores and 128GB ram and nvidia rtx A4000. So it’s no slug, but it couldn’t handle it. Even weirder is that after the crash my cpu was kept at 100% while I couldn’t see FME as a process anymore.
